Dustman
Don't know if anyone has done this / posted this before, I was doing a search on here prior to this project but couldn't find anything.
When we first got our Viper last year we immediately changed the exhaust to a Corsa Track (after doing some extensive research in here) and it sure made a huge difference, not only to throttle response but also the sound was more 'adequate' for the Viper
However, I always felt like the driver side exhaust lacks 'flow' of some sort so I decided to take off the Cats, not only should this help airflow but also cut down on cabin heat as many of y'all have reported, but I figured it should improve the sound a bit as well (ALWAYS a welcome side-effect I suppose)
All jacked up and ready to CHOP
(took the side sills off at home and drove the Viper to the Muffler shop ~ 15 miles without panels )
In order to keep the Corsa Track in place so the tip will remain "aligned" with the side panel opening, my muffler guy spot-welded two jacks to the exhaust and to the ramp (unorthodox yes but 'effective' )
that's the driver's side "Cat-assembly"
and IN went a connecting straight-pipe
Upon closer inspection of the driver side Cat we realized the possible cause of the 'lack' of airflow on the driver's side
A BUSTED CAT ! (at only 11.000 miles)
ANYHOO - all I can say is .......... "WHAT A DIFFERENCE" , not only in performance but the sound is just INCREDIBLE
[media]http://www.youtube.com/watch?v=yQ2FLGedJfU[/media]
