Some guys worry about pulling to ******* the shifter before the shift.
You couldn't pull the shifter out of gear under hard acceleration if
your life depended on it
interesting, thanks for the info
800 or 1000 hp halfshafts? Just curious!
Good start.
Couple obvious tips:
Higher RPM for a holeshot and 1.3-1.5 60ft.
Start pulling back hard or pushing up for the next shift. This nearly
insures a solid shift as you pop the clutch an lightning fast shifts.
I assume you have the HD half shafts.
