To put things in the proper prospective. I just purchsed a spare trans. While I was looking I could have bought a new trans for $2,300. I believe it still may be available, look on Ebay and this board. To remove and replace the tansmission cannot be more than a four hour flat rate.
Another direction, John Dinoto (248-232-1110) probably repairs more T56 transmissions than any other single individual. Many dealers use John without the owners even knowing who repaired the trans. I just had John repair and enhance a transmission. You would be surprised what the real cost of repair is.
$2300 is ALMOST 2 times as much as an extended warranty.
AND he got a brand new warrantied tranny without crapping around with Ebay, hoping the guy isn't a scammer. Not having to have it shipped etc etc etc.
Less money and a better deal sounds good to me.
And he is covered for all of the following with the Maximum Care warranty:
The most comprehensive plan available, Maximum Care offers coverage on virtually all mechanical components, with only a $100, $50 or $0 deductible. It even includes Trip Interruption coverage. Over 5000+ components covered under this plan.
Engine:
Cylinder Block and all Internal Parts, Cylinder Head Assemblies, Timing Case, Chain, Gears, Belt and Sprockets, Vibration Damper (Harmonic Balancer), Oil Pump Cylinder Block and all Internal Parts, Intake and Exhaust Manifolds, Core Plugs, Valve Covers, Oil Pan, Turbocharger Housing and all Internal Parts, Turbocharger Wastegate Actuator, Water Pump and Housing, Fuel Injection Pump and Injectors (DaimlerChrysler Diesel Engines only)
Transmission:
Transmission Case and all Internal Parts, Torque Converter, Drive Plate, Flex Plate, Flywheel, Starter Ring Gear, Bell Housing, Oil Pan
Front Wheel Drive:
Transaxle Case and all Internal Parts, Drive Shaft and Axle Shaft Assemblies and their Housings, Constant Velocity Joints and Boots, Front Wheel Bearings, Differential Cover, Oil Pan, Transaxle Speed Sensor, Transaxle Solenoid Assembly, PRNDL Position Switch, Transaxle Electronic Controller, Flywheel or Torque Converter, Drive Plate with Starter Ring Gear, Bell Housing
Rear Wheel Drive:
Rear Axle Housing and all Internal Parts, Axle Shaft Bearings, Drive Shaft Assemblies, Drive Shaft Center Bearings, Universal Joints and Yokes, Axle Shafts
FourWheel Drive / All-Wheel Drive:
Transfer Case/Power Transfer Unit and all Internal Parts, Viscous Coupler, Front and Rear Axle Housing Assemblies and all Internal Parts, Rear Driveline Module, Axle Shafts, Axle Shaft Bearings, Constant Velocity Joints and Boots, Drive Shaft Assemblies, Drive Shaft Center Bearings, Universal Joints and Yokes, Disconnect Housing Assembly, Differential Carrier Assembly and all Internal Parts, Output Ball Bearing and Flange, End Cover, Overrunning Clutch, Vacuum Motor, Torque Tube, Pinion Spacer and Shim
Steering:
Steering Gear Housing and all Internal Parts, Power Steering Gear, Power Steering Pump, Steering Shaft and Lower Coupling, Rack and Pinion Assembly,
Air Conditioning:
Compressor, Clutch, Coil, Condensor, Evaporator, Receiver-Drier, Expansion Valve, Hoses and Lines, Low Pressure Cut-Off Switch, High Pressure Cut-Off Switch, Clutch Cycling Switch, Instrument Panel Control Assembly, Power Module, Air Conditioning / Heater Blower Motor
Engine Cooling and Fuel:
Cooling Fan, Clutch and Motor, Coolant Temperature Switch, Water Pump and Housing, Electric and Mechanical Fuel Pump, Fuel Tank Sending Unit, Fuel Tank and Lines
Front Suspension:
MacPherson Struts, Strut Mounting Plates, Bushings and Bearings, Upper and Lower Control Arms, Control Arm Shafts, Control Arm Bushings, Upper and Lower Ball Joints, Front Wheel Bearings Front-wheel-drive vehicles only
Rear Suspension:
Rear Leaf Springs, Rear Coil Springs, Auxiliary Springs, Spring Interliner, Spring Bushing, Spring Shackle, U-Bolt Rear Spring, Spring Hanger, Axle Trac Bar, Lateral Link Arm, Shock Mount Plate, Rear Trailing Arm Assembly, Stabilizer / Sway Bar, Stabilizer / Sway Bar Link, Stabilizer / Sway Bar Bushing
Electrical:
Starter Motor and Solenoid, Alternator, Single Board Engine Controller (SBEC), Powertrain Control Module, Distributor, Ignition Coil, Coil Pack Assembly, Voltage Regulator, All Wiring Harnesses, Electronic Fuel Injection System (excluding injectors), Windshield Wiper Motor, Wiper Control Module, Manually Operated Electrical Switches, Neutral Safety Switch, Temperature Sending Unit / Switch, Body Computer, Body Control Module, Rear Window Defroster, Power Window Motors, Power Window Regulator / Flex Track, Power Antenna, Power Seat Motors, Power Door Locks and Linkage (excluding latch assembly), Keyless Entry Receiver / Module, Trip Computer, Message Center, Overhead Electronic Vehicle Information Center, Overhead Electronic Compass / Temperature, Power Sunroof Motor, Convertible Top Motor, Electric Mirror Motor and Controls, Cruise Control Servo, Headlight Door Motor, Concealed Headlamp Module, Mopar Accessories (Authorized DaimlerChrysler facility installations only), Factory Installed Radios and Speakers (Includes CD and Tape Players)
Instrumentation:
Electronic Instrument Cluster, Amp / Voltmeter Gauge, Temperature Gauge, Tachometer, Oil Pressure Gauge, Turbo Gauge, Electrical and Mechanical Speedometer
Brakes:
Master Cylinder, Assist Booster, Wheel Cylinders, Disc Brake Calipers and Pistons, Brake Lines, Hoses, Fittings, Seals and Gaskets
Proportioning Valve, Anti-Lock Brake Systems Hydraulic Assembly, Pump Motor Assembly, Controller, Sensors and Relays,
