Dimitrios
no i didn't upgrade the pump. car seems to be getting fuel...
Very good exemple Dimitrios.
If the required high octane fuel is not available sometimes it is better to run with a lower boost. It will yield to more HP since you don't have to retard as much the ignition. Since you stayed with the 10lb pulley you had to pull back some a lot of ignition and you lost power. With the race fuel you gained the power back.
Dimitrious, what plugs did you have before the bosch ? Do you have the number on the side of the plugs .
I don't think that they are bad plugs but for a high boost if would be logical to run with colder plugs. The bosch was too cold for my little 6.5lb boost.
D, This is the correct answer to your problem...call Sean ...Problem will be solved...Al...Hi D, It took me a few times to get mine right too. Dave gave me a larger W/M injector for one side. Overnite Shawn you card, with your dyno sheets..explain whats happening he will send you a few different cards with some different timing/fuel programs, change the injector, and you will be running great...keep the 96 PCM, that has nothing to do with your problem. He sent me 3 cards and the first one did the trick...Keep the card you have now for your race fuel program...NO MORE PINGING...AL...
