DLM Stage 1 vs. Sean Roe
J DAWG
MS
Speaking of that graph. Why does it initially spike lean. Is that the pcm recognizing the boost and then accomidating for it.
Joseph Dell
Atlanta, GA 30338
Great question. I don't know the answer to that. What I _do_ know is that _every_ centrifugal dyno graph I've ever seen has the spike at the beginning...
This even happened with my ATI D-1 on a mustang... And that had a FMU and not a tuned computer.
Perhaps one of the tuners can shed some light on this one. Inquiring minds want to analyze graphs!
JD
GONABITE
Albany NY
I believe that initial spike is normal for the stock PCM even if you look at a stock dyno pull you will see the same thing. I have not dynoed my car with a wide band o2 since I intalled the VEC 2 but I beleive Sean has gotten rid of that inital spike with his progamming capabilties.
WESTCOAST JASON
Temecula, CA
My dyno charts showed the same initially also. I think you are right about it being normal for a stock PCM, but I was eventually able to flatten it with my setup also.
