So the other day I picked up a Miller 6990 kit, which has the control arm bushing remover/installer, the caster fixtures (for gen 2 unfortunately), and the inclinometers and switchbox used by the DRB III to read caster. I don't have a DRB III, but I have some background in sensors as I helped to set up the test department where I work and deal with sensors and DAQ equipment on and off. I figured the sensors were probably typical 0-5V output or 4-20 mA like most lab style sensors you can find for data acquisition systems. My thought was I would plumb the signals into a simple microcontroller like an Arduino or even just a volt meter and figure out what angle corresponds to what output. Well, I was wrong. These sensors are a little more complicated than I was expecting, so I'm wondering if anyone out there has any background knowledge of the DRB III tool.
I took the switchbox and sensors apart and pulled the numbers off of all the chips I could see inside and have been trying to trace the wiring to get an idea of what goes to what. As best I can tell and guess, the switchbox itself outputs an RS232 signal to the DRB III. That in and of itself would be easy enough to read with most microcontrollers. I think the DRB also supplies 12V to the switchbox over the cable, which is not exactly in the RS232 standard pinout, but makes some sense. I haven't tried hooking it up to anything to try to intercept data just yet, so I don't know if the sensor just constantly outputs data without being asked or if it will require a request for data before it sends. That is the big question I have right now I'm hoping someone might know.
The sensors themselves are also quite a bit more complex that I was originally expecting. While I think at their very base level they are probably a simpler output, inside the aluminum box is a sensor on a PCB with a microcontroller (coincidentally the only chip I can't find a datasheet for). The PCB does have the wire hookups clearly marked as RX, TX, +, and - though, so guessing it is also outputting something like RS232 serial data. I would rather not remove the sensor from the board, even if that may be the easiest way to do what I want.
So long story short, any electrical engineers out there that want to help out in trying to reverse engineer the setup? Or does anyone have a lot of in depth knowledge of how the DRB III communicates with the external sensors? If I can figure out how these sensors talk it would be easy enough to build a small box that would just be a live readout for them to let anyone use them to measure caster without needing the $3000 DRB III. The cheaper DRB III emulator isn't an option as it can't talk to the external sensors, it's just software. If all else fails I could always just get some generic inclinometers and find a way to attach them to the caster brackets, but this seemed like a novel enough side project and the parts are reasonably available.
Some pictures inside the switchbox and the sensors themselves:
Switchbox:
Inside the sensor:
Other side of the sensor board when removed from the case:
Switchbox:
Inside the sensor:
