01 RT SNAKE
I took the car to get dyno'd today and to get the air/fuel readings. I'm running a NX Wet Kit. The FJO mini computer is set to start at 2600 rpm (30%) and 100% at 3000 rpm. It is 100% all the way to 5700 rpm.
My air/fuel was absolutely terrible. Below 10:1 on the chart. I followed NX's jetting recommendations.
100 shot 35 N20 / 18 Fuel
150 shot 41 N20 / 22 Fuel
200 shot 52 N20 / 33 Fuel
I called NX and they agreed that the car was running way too rich and was hurting the numbers. The tech recommended I up the N20 jet and leave the fuel jet alone. On my last run I ran a 41 N20 and a 18 Fuel. It gave the best air/fuel readings but the numbers were still low. I gained a whopping 56.5 peak HP.
Here's the graphs...
This is my pre-nitrous dyno done last year at a different dyno shop.
My three runs were:
421.91 hp / 451.16 tq
429.75 hp / 456.73 tq
428.65 hp / 459.19 tq
This is my baseline today. I'm running a NGK plug one step colder than stock. My numbers were down just a bit (about 3-10 peak hp torque pretty much stayed the same). I'm guessing it's just a dyno variance.
418.2 hp / 457.8 tq
Here's the 100 shot....
463.8 hp / 536.9 tq
Here's the 150 shot...
468.5 hp / 563.7 tq
Here's the 200 shot...
466.1 hp / 574.5 tq
Here's the 41 N20 and 18 Fuel jets
474.7 hp / 568.0 tq
Notice, the air/fuel is much better on this run, however, it's still not close to the approximate 125 HP shot.
My bottle pressure was around 925-950 psi on all the runs. NX said it should be 1000-1050 psi. I still don't think the bottle pressure being slightly low should have resulted in a 150 hp discrepency on the 200 shot.
Anyone care to diagnose this and tell me what's wrong?
My mods are K&N's, tubes and a Corsa exhaust.
Mike
2001 RT/10
My three runs were:
418.2 hp / 457.8 tq
463.8 hp / 536.9 tq
468.5 hp / 563.7 tq
466.1 hp / 574.5 tq
474.7 hp / 568.0 tq
Mike
2001 RT/10
