WESTCOAST JASON
I could not resist seeing if those 'tornado' style inserts made a difference on the dyno for Vipers. Using a set of them on the shop car, I made back to back runs two different times, with and without the 'vortex creators' placed in the smooth tubes. They don't work.
Then, I figured I would try more things. The following was surprising. Using the stock air box (with rain mod and 3" back half) and K&N's netted me 540RWHP and 562 peak torque. (the norm for this particular car) I then removed the airbox and ran with the tubes only. I lost a solid 10 horsepower on the pull without the box. Then for fun, I removed the tubes (ran with nothing on the TB's) and the power dropped to 522! I knew the factory box was a good design, but booting it cost this car 18RWHP. Amazing.
Looking around I found some 3" fuel line (yes, 3" clear fuel line used for fill necks on sandrails) I made myself two 24" long 'smooth' tubes. I ran these without the box on the 'end' of them. The horsepower was even worse, but the torque went up! (not as high as the 562 baseline, but higher than it did without any tubes)
Just to run another baseline and be sure external factors were no affecting this I put the car back to normal and did another pull. 537/564. Back to normal even though the car is more heat soaked than when I started.
At this point I got tired and came home and wrote this but I am so interested in how this works and why, that I will do a more scientific test sometime soon.
For those few that run conical K&N's on the end of the throttle bodies, maybe you should get some dyno time on that mod, I am curious if this affects all Vipers regardless of mods.....
