E85 on a Gen IV??
mclarengts
SC
Is anyone running E85 on a Gen IV? Any information? Any numbers on gains? What's needed to complete the conversion?
3whitevipers
Sarasota, Fl
Given that E85 contains less energy per gal. than either plain gas or 10% gas/ethanol, I sure don't expect that you would have any power gains at all.--Dave
E85 is a higher octane though, so if the engine is built for it you can actually get more power. However, without changing compression or adding boost you likely wouldn't see a gain.
srt4evah
I don't know about Viper engines and E85, but I know you can advance the timing a bit with the higher octane of E85. I have an SRT-4 tuned for E85 that puts down ~475hp at the front, that's a combination of being able to run more boost as well as advance the timing a good amount because of the E85.
You also need to dump about 30% more fuel with E85, so keep that in mind. Most cars require larger injectors and a bigger fuel pump to make it work.
gb66gth
Big-D
I think you need larger injectors and a tune, if I am not mistaken.
tractor1996
