Excuse Me.....I NEED to BURP!!!
1KoolAsp 14TA
Long Island, New York
I drained my coolant and after I properly replaced it with fresh coolant, the tempature gauge is now running on the third mark on the gauge. Where it normally ran in the center mark of the gauge. I installed schrader valves in the hoses in order to properly bleed the system of air. Some did bleed off, but I can't get the rest of the air out. Every time I bleed the system, only anti freeze comes out. NO AIR!! HELP me PLEASE! Also to note, my overflow tank is full. I have been working on this for a looonnng time and still, can NOT solve this problem. Car is just running so much hotter than it did before. Any suggestions. I hope someone call help.
95Viper
Phoenix
It would be strange but not impossible for the known waterpump issue to have bit you.
I'd be suprised you have air in the system with the hose valves not releasing air. Also, if you remove the radiator cap and the bottle is full, I don't think air is your issue, how's your puke tank in front facia?
You simply might have the wrong mix of coolant. Test it for cheap insurance.
tractor1996
