Fist time post.
Anthony - 98 GTS
Houston, Texas
Welcome, with the smooth tubes and filters you should have between 420-430 rwhp.
You should run a high 11 to a low 12 in the 1/4 mile depending on your driving and track conditions.
Chuck 98 RT/10
tampa, fl USA
Remove the rear muffler. Replace it with an X, H or straight pipes at any muffler shop for $100 to $150.
Lower your rear tires to 21-22psi for the dragstrip.
Put your real name in your sig.
Mike H
West deptford NJ 08066
Originally posted by Bandit:
Come on guys some help please!!!!
Bandit....Have patience....39 minutes later....First thing to learn about a Viper, is it has incredible torque, which can get you into trouble...QUICK!!! Make sure your tires are warmed up and the car pointed straight before you hit the gas on a street. Too many people crash over this alone.
As far as at the track, with practice, patience, you can hit low 12's, to high 11's.
Good Luck!!!
PS: As ViperMad said, use the search tools and you can learn a lot about your viper.
tractor1996
