I saved this post just in case it ever happened to me. I have not tried this:
I shaved my own (instructions enclosed)
Posted by Tom Friend (99 GTS Mikita Maniac) on Monday, 18 September 2000, at 9:32 a.m., in response to What is the best cure for Flat Spots on the Tires??, posted by Eric Lesher on Saturday, 16 September 2000, at 9:41 a.m.
I phoned all over 3 counties and could not find a single tire shop with a shaver who would do the deed. Since I had nothing left to lose, I thought I'd try it myself... (liberal grunting noises here, ala Tim Allen)
1. Put the snake on blocks- all fours.
2. Remove rear tires, put front tires on rear. Inspect the tires very closely, and remove all screws, rocks, metal bits, etc.
3. Roll the tire and hold a piece of sidewalk chalk up to that big rain groove strip in the center of the tire. The chalk gap will show you the location of your flat spot(s). Feel the spot with your hand and get an idea of how big it is. Mark a solid patch an inch or two bigger than that with the chalk- side to side.
4. Idle car in fourth gear. road speed ~18-20 mph.
5. Get out your Mikita angle grinder. I used a 36 grit steel grind abrasive wheel. Use light pressure and be patient. Work side to side. Be patient- it took me about 20 minutes per tire. You will feel the "bump" becoming less and the chalk spot on the tire will become narrower. I got a little bit impatient and only ground until the chalk strip was 1 1/2 inches wide. Less would be better, especially above (ahem) legal highway speeds.
6. Swap back the tires and try it out.
7. Clean up all the rubber dust off the garage floor so the house keeper doesn't get pissed. ;-)
NOTE: One interesting side-effect was that the front tires got real sticky after this procedure. I tried an "anchors out" stop after this and the rears actually locked up! I have a 100% stock brake system- no prop valve mods.
Seems that roughing up the tires might help for certain conditions like autocross or 1/4 mile. The condition is not lasting, as 250 miles
