You mean the orange front side marker / Indicator?
Thought we had just been down this road? Depending on what side of the car you are working on, turn the front wheel so that the front of the wheel is turning in towards the inner wheel arch.
You will then notice a large rubber **** in the front of the wheel arch.
Remove the rubber ****, and put your hand through the hole and feel the back of the Side marker lamp.
Twist the bulb holder to release and pull the wire with bulb holder back through the ********* so that you can replace the bulb.
Replace Bulb, re-fit bulb holder in back of lense and replace Rubber ****.
Then do the same again to the other side of the car.
