Fuel Delivery Systems
utahviper
Utah
I am having a problem getting enough fuel to my engine and I was wondering if anyone knew of any options out there. My stock fuel system puts out 55-58lbs of pressure and I am trying to get it to 70-75lbs.
I was told that there is a possibility of altering the fuel regulator but I do not know.
Any help would be greatly appreciated.
Thanks Todd
9 seconds
Texas
Why do you need so much fuel pressure? TNT made a stroked, N2O powered Viper run a 9.5 second quarter mile with the stock fuel pump.
If you need improvements, talk to John at HMS. He offeres a fuel pump upgrade for just a few hundred dollar bills.
wmw1
Todd,first of all how many miles are on your car?You are correct in saying that you may have fuel pressure,But you may not have correct fuel volume.Remove your fuel-filter and sample the fuel into a clean container.If the fuel is dirty-change the filter.We do have an open return fuel system which will allow you to regulate the fuel pressure settings(external),with an adjustable fuel pressure regulator&high volume secondary fuel pump.Which allows the fuel to flow through the intake manifold- fuel rails,then returning the fuel back into the fuel tank.Which gives the fuel time to cool-down and decreasing the chance of fuel peculation.There is also noted that this system is linked towards free HP.Wm
