dipapa
Here are my dyno plots with Stock pistons, heads, cam, injectors, heads and stock mufflers. A couple neat additions on the Paxton S/C kit courtesy Todd Abrams @ A&C Performance. We also did allot of work on the exhaust for the right balance of power and sound.
I have had owned the car for 1 year and I went through allot of dyno tuning bot N/A and S/C. Took many iterations to get that VEC3 with S/C tuning worked out. Thanks to A&C Performance, and much determination and I think the car is finally where it needs to be and I have reached my goal for good power and drivability both part throttle and WOT.
The data is SAE corrected. I was running 91 oct and it was 90-95 degrees in the shop. After we felt the tuning was optimized we let the car cool for 30 minutes. The times stamps between 3 dyno were 15 minutes. The first 2 runs were very identical. By the third run, same tune, I believe we were getting a bit heat soaked. Thats the only explanation i have for the 2% lower change for the 3rd run.
Thanks Todd for all your dedication and getting my car done right!
