Gen 3 vs 4 blocks and cranks
Cape Coral, FL
All gen 5 internals fit gen 3block I did it with mine
ehhhhhh
They fit,
*IF* you bore and hone the cylinders.
*IF* you clearance the oil gallery on certain years.
*IF* you change the flywheel bolts.
*IF* you add the alignment dowel for 03/04.
*IF* you add the crankshaft position sensor for 03/04.
Not exactly my definition of "fit". It requires knowledge and modification.
Fire196
Peterborough, ontario, Canada
I got the complete rotating assembly from a 9 liter build and only things that had to be done were bore out to 25 thousand over and have crank shortened 1/2 in. Used my flywheel with Gen 5 hardware and Gen 4 heads with drag pack intake and prefix reflashed my computer
BadAzp
Las Vegas
Not really on this block/crank subject but damn throttle bodies are different between cars and trucks too.
Luigi93
