Gen1 Injector HP
TexasPettey
Austin, Texas
Anyone have an idea of how much RWHP the stock Gen1 fuel injectors can handle, with and without a fuel pump booster?
Dan Cragin
LA, CA
The Gen 1 injectors are only good for about 520hp at 55psi. If you change your cam, add performance heads and headers. You will need the larger Gen 2 injectors and a better computer calibration. Gen 1 cars tend to run lean on the top end and get worse with modifications.
DC Performance Inc
DC Performance: Proven Performance
310-841-6996
ACELLR8
Harrisburg, PA
I would agree with everyone get a set of used Gen II injectors. Gen I injectors are 25 # injectors and Gen II are 29# injectors.
I changed mine on my car and it is only making 469 RWHP NA. It was running pretty lean on the top, after the injector change it has been fine.
Usually can pick up a set for $100 to $150 from someone who modified and has them laying around.
ROIII
