Wendy Macedo,
The cards that you refuse to return to me are not yours - they came with the Roe Supercharger.
How do you expect me to get my car to you if I can't even drive it?
- Kenny Katowik
Well, this is pretty simple to me here. Kenny paid an EXPERT to BUILD his car to make at least the high 700’s RWHP using the Roe and VEC II. The EXPERT supplied the heads that Kenny paid the EXPERT for, and that Kenny paid the EXPERT to install and subsequently tune. The combination was supposed to be drivable and throw no codes.
Statement of facts as I know:
I) Car was turned over and approximately $20,814 (estimate #200) was paid to have a Viper that was at least high 700 RWHP and drivable as a daily driver utilizing ROE blower, Striker Heads and VEC2. Striker Heads were paid for by Kenny in the amount of $6,500 to EXPERT.
Ia) Car made max 721 RWHP to date.
Ib) Kenny has to be real careful of high idle hang up at 2,000 RPM even in gear (like cruise control) and violent surging and bucking at low RPM, i.e. not drivable as a daily driver and even now car has less than 1,000 miles on this after the rebuild and 500 mile break in done for the EXPERT!
Ic) Total bill was for $27,895.91 invoice #607
II) Car was promised to be completed on or about early April 2005
IIa) Delayed due to heads not being shipped because rocker arms were not installed and promised the car would be done by May 2005 because engine would be delayed installing because of the missing rockers.
IIb) Delayed due to and promised by June 2005, but Kenny asked EXPERT about safety concerns and Kenny purchased roll bar.
IIc) Delayed due to tuning problems and promised not to release until the car was "right"
IId) Delayed due to tow to Ohio and promised before July 4th as the EXPERT was going to Ohio to drop off parts.
IIe) July 1, 2006 car arrives with EXPERT driving car of off towing trailer and meeting Kenny at local Dodge dealership and turning car back over to Kenny.
III) The EXPERT said to Kenny he had car tuned and running with no problems other than an intermittent loop problem when starting engine cold that causes the engine to need to be turned off and restarted when Kenny received the car back.
IIIa) Engine was not broke in at all, having approximately 50 miles on the car when delivered back to Kenny.
IIIb) The EXPERT said the car must be driven 500 miles to break the engine in and then get tuned again by him (the EXPERT), and that the EXPERT was coming back to Ohio in 2-3 weeks. The EXPERT was tuning another guys car in Ohio and was going to tune both cars at the same time.
IIIc) Expert did not do break engine in, Kenny did.
IIId) EXPERT did not adequately tune car per promises by EXPERT
IV) The EXPERT said, he would not give the car back many times over the phone and in emails until it was "right"
IVa) The EXPERT said there might be a problem as he gives the car back to Kenny, that there might be a problem with the car getting stuck in a loop cycle and the car might have to be occasionally restarted.
IVb) Kenny's Viper did not make enough boost when started around April 6, 2006, and the EXPERT says it was because of the "heads flowing too much" and was flowing 7 lbs. with a 10 lb. pulley. EXPERT charged for and installed a DW pulley and some other small items again not included in original estimate to compensate for head flow. Then after DW pulley installation, the EXPERT told Kenny he could get engine to 12 lbs of boost, but then engine boost would drop off to only 8-10 lbs of boost.
IVc) Car has to be restarted 99% of the time to get car out of loop.
IVd) When Kenny drove home with his newly tuned Viper that he paid $27,895.91 thinking he received what had been promised minus some horsepower, he quickly realized something was wrong. Kenny experienced violent surging and bucking and immediately contacted the EXPERT the SAME DAY via messages. As the day's temperature increased to approximately 95 degrees Fahrenheit, the car became totally undrivable. More messages were left and the EXPERT called back the next day.
IVe) The EXPERT could not understand how the car would run the way Kenny described as the EXPERT said the car ran "perfect in Florida." EXPERT said the difference in altitude was the problem for Kenny's Viper running the way it was.
IVf) The EXPERT said he was coming back in a few weeks and car would be adjusted. The EXPERT asked Kenny to try and break it in and see how it runs under different weather conditions so at least engine is broke in for tune.
IVg) Kenny saw a post in the VCA site about PCM and TPS ground reducing surging problems and brought it to the EXPERT's attention. The EXPERT acted like he never heard of this according to Kenny, the work had not been done on Kenny's Viper and Kenny’s Viper Tech did ground work and it helped the surging problem quite a bit. Still, car was not safe to even drive despite problem being "better", the tune was still way out to be drivable on the street safely.
IVh) In August 2006 EXPERT told Kenny that Kenny could run car at Viper Nationals via email, despite all these documented problems. Reluctantly, Kenny trusting the EXPERT ran car the Viper Nationals. The first run down the track, there was a loud muffled boom under the hood and Viper stopped running! Oil pressure went to zero, and Viper was unable to restart. The PCM fuse blew with a large hole in the fuse like the fuse exploded-nearly dime size. Kenny left a phone message for the EXPERT for resolution to the problem. Installed new fuse, and same fuse blew again on second run. Kenny left amore phone messages for the EXPERT for resolution to the problem. Kenny's water/**** line that was reinstalled for engine R&R was leaking on an electric motor that the EXPERT installed for crankcase ventilation system. Kenny's confidence was broken to know that the car has track problems now too let alone street problems.
IVi) Kenny has made numerous attempts to resolve this issue via phone and email with the EXPERT, including mailing VEC II cards. Current VEC II cards still make car unusable due to surging, bucking, high idle hang up, hard to start, dies in traffic and Kenny found out cam should find out at 1000 RPM yet car idles at the around 700 RPM.
V) The EXPERT then said he was having trouble tuning with VEC II before the EXPERT brought the Viper back to Kenny.
Va) Kenny was offered a AEM computer for a whopping $4,500 saying it was a discount!
Vb) Kenny is dissatisfied as that should have been part of the original estimate if in fact he was dealing an EXPERT, and did not anticipate that substantial increase in the price.
Vc) The EXPERT reiterated that it would be so much harder to tune the VEC II over the AEM, yet the EXPERT never said the he could not tune with the VEC II.
Vd) The EXPERT received Kenny's VEC II cards, and lost them and then found them delaying at least 2 weeks according to Kenny. Kenny was unable to drive car in the interim. Again, the EXPERT said that Kenny would be much better off with the AEM.
Ve) Kenny found out cam should find out at 1000 RPM yet car idles at approximately 700 RPM, When Kenny asked the EXPERT about 2 weeks later why wasn’t the idle set at the correct RPM before it was delivered, the EXPERT said "I thought you were going to buy the AEM."
Vf) The EXPERT has had two revisions from the original programs so this is the third set of programs currently. The third set of programs have literally totally crippled the car to the point where the surging and bucking makes the car extremely dangerous to drive and the car can barely go 40 MPH now.
Vg.) The EXPERT now refuses to return the VEC2 cards that Kenny had paid for.
RESOLUTION Suggestion: The contract as I see it was not met in terms of money, horsepower, drivability AND reliability. The EXPERT should buy an AEM for Kenny IF needed and pay a tuner to fix all problems in my opinion and issue a SINCERE apology to Kenny. Kenny should choose tuner and the EXPERT should foot the bill to do the job to tune this right. This is very sad to see this happen in the Viper community, let alone from any human decency perspective. The forgoing is just my opinion based on what I have seen posted and other sources, however suffice to say this should never ever have reached this level if it was handled differently.
Gary, 2000 GTS Roe S/C Owner
