KNG SNKE
Tape instead of wax. You CAN use wax, just a lot of cleaning in the end.
Whatever, but I just checked Tire Rack and the 305/30/18 and 335/30/18's are in stock....the 335's are actually priced below $200....they must be getting out of making that size.
Going with the Motul 600.
I can't use wax though because of the Matte finish. Any ideas on what to cover the paint with other than wax?
Side note: I also heard that a viper owner could be the reason for this. He sued Kumho after wrecking his Viper. Don't know if there is any truth to this.
1-Check/change all fluid - Yes
2-Add a quart of oil - Just up to the full line, no more.
3-Make sure not to overfill new brake fluid (use upgraded fluid) - Just up to the full line. Bring extra and add as needed throughout the day.
4-take out some power steering fluid - No. Flush it and fill with new up to the full line. Make sure the cap is tight.
5-Get the Bling front rotors off and throw stocks back on (I kept them) - Probably. I don't know what blingers you have.
6-Good tires on stockies all around. - Yes
7. Fresh brake pads if your current pads are worn too much.
Great idea! I can't use wax though because of the Matte finish. Any ideas on what to cover the paint with other than wax?
-Tim
Whatever, if you want to get new, but 4 year old tires to race that are part of a "closeout". Yes, check Tire Rack again. They state the production timeline on these tires as well.
I've heard from at least half a dozen good sources including Jon B [who I called to order these tires] that these will not be made in viper sizes [I used 345's in the rear].
Your sources are wrong. I bought a set last year that were one year old. That's 2....not 4. Perhaps they're no longer making them but the 4 year old claim simply isn't correct. Never had a problem with them but that doesn't prove they're good. Maybe you spoke with Jon B on a Monday morning or something......
I'd like to hear more about that.
Can anyone let me know how much Brake fluid I will need once I drain the entire system? Also any recomendations for power steering fluid? How much there also?
Any tricks/tips to draining the brake system/power steering system?
Once agian love all the help people!
Anyone have a used set of 18's they are looking to come off? Not looking to spend a ton obviously. 275-335 or whatever for the fronts 305's etc.
Thanks again!
-Tim
Tim, a liter can should be enough to flush out the brake system and for gods sake if you want the best don't use Motul, spring for the Castrol SRF brake fluid. I call John Purner from CCW Wheels and buy yourself a set of track wheels in the size you want at a good price. With 305s I'd go with a 18x11 or 18x12.
Brake system doesn't take much. Bleed from furthest spot away from the master.....RR, then LR then RF then LF (at least I think that's the best order to bleed them in). I think a quart will do ya just fine.
I have a couple old R6 take offs....but you're pretty far away.
-Tim
Well I don't mind paying for shipping!!!! Or whatever for that matter!!! I can't NOT find any take off's around here.
I guess MTGTS how much do you want for your 888's? And how much life (estimate) is left on them???
I think shipping is usually about $20 per tire which is COOL with me. Can either one of you guys send some pics???
Thanks a lot I really appreciate the help, I would like to go with the better tires just for mounting and stuff but don't want to put a ton of cash into this deal!
tim@modern-entertainment.com
-Tim
I'll send you some pics tommorrow sometime. I haven't looked @ them in awhile as they were my spare set
A Gen 1/2 brake system can be fully flushed with one pint of fluid. Until you've done it several times, it's better to plan on two pints.
I guess you missed this ^
Buy one quart of Mopar power steering fluid.
