LPDesRoche
Ok I have tried everything I can to adjust the door hinges on my GTS (per VCA how-to instructions and a fwe extra methods) but I am afraid that at least the passenger side one may be too far gone. Even when freshly adjusted and fully tight I have to have the door tilted up a bit more than I would like to account for the sag that happens when you let it go. I also thing that my hood needs to be adjusted forward a bit so I can bring the door itself a bit forward to allow my door panel a little more clearance where the armrest part nears the weatherstripping. Both drivers and passengers door panels have signs of wear on this area from scrubbing on the weatherstripping. What are my options on this, are the door hinges still available? I have yet to remove the door panel, but I have heard the hinges are bonded to the inside of the door and not bolted. If that is in fact the case how do you go about changing them out? Any suggestions on this?
