Halloween mods
V10 ACR
San Diego, CA
No work today so I worked on the viper. I was recently at VOI9 and with all the driving and the temps in Vegas, I was hot too much of the time. I saw DC performances vents at the vendor show, but the viper tax was too high. I got some premium stainless steel mesh and cut out a portion of the resin side piece. Took all of 40 min per side including removing the side sills. Not the cleanest job, but I think it looks good and will help keep temps down. The side sill insulation is in tough shape with the metal portion by the cats has vaporized. I may need to replace it soon.
New vents
I also had a front vent kit from Roe that I had been meaning to install for quite some time and I finaly got around to all the cutting and riviting. Once I started the install it became very clear why this can lower the temps. There should be a ton more air flowing through the various radiators.
It looks reasonably clean from underneath.
You can hardly tell from the front, even at a low angle.
Can't wait for more track time!
ViperJoe
Virginia
V10ACR do you have a corresponding opening at the rear of the sill?
Pics please......
V
V10 ACR
San Diego, CA
Vents are not needed in the rear. The back of the sills are wide open and direct the air under the car. I have the contact info for the wire mesh company on another computer. It was from a CA company. They typicaly sell a min of 12 sq ft at $6.25/ sq ft. They do sell samples that are 6"x6" for $8.00. I just bought two of the samples and trimmed as needed. I'll post the info when I am back in the states.
ViperGTS
>>>Isn't there an issue with water entry? <<<
In another thread here the Wizard wrote that by letting water during rain into the side sills ONTO HOT CATs will destroy them ... perhaps he can chime in.
V
V10 ACR
San Diego, CA
O1 RT Snake,
That is the company I ordered from. I ordered two "samples" at $8.00 each. Took a week or so to get. It cut prettey easily with tin snips and was secured with small pop rivets.
I have not been too woried about rain on the hot cats (San Diego has very litte rain. When I had the side sills off, the exhaust was pretty rusty but still has another 35,000 miles in it.
Carlos580
