Rollin4
Vipermania. They are modified to fit the top.
Jeff
By "modified" windows, in what way are they modified? I would hate to destroy a set of $1,000. windows trying to "modify" them.
Jeff
Dennis, I know that feeling and that's exactly what I wanted to avoid.
Rollin4,
"Destroyed" is far from what happens. When I first opened the package for my Vmania windows my heart sank at the thought of cutting such a beautiful/expensive piece. The reality is, the top would look stupid if I retained the added 2" of height at the rear. The modification is the removal of material starting from the original dimension at the front, then cutting a strait line to about 2" below the original dimension at the rear.
Fortunately, the modification is quite easy for me to do and can be done quickly and they still look great! If your concern is that these windows will no longer seal against any other top, you are correct. If you want to keep your soft top or a solid hardtop, you'll need a separate set of windows for those.
Sorry about that, it falls in with the styling I insisted upon.
Jeff
