Vital Velocity
So a couple months ago I parked the viper after fairly normal driving and it pissed coolant everywhere. I had to get it home so filled it with water and tried the drive home in about 65-70 degree weather, mostly highway. The car stayed cool (cooler than it usually did) for the majority of the 60 mile drive until I was about a block from my house where it started to warm up. Got it home and it sat for a bit
Well finally getting time to get around to it the past week or so, put more coolant/water in it and started it, it stayed around 200 once warmed up at idle then started to heat up again, after shutting down it pissed coolant. It does have a DLM Paxton kit on it and the following cooling components changed in the past year and a half
-water pump
-thermostat
-coolant pressure cap
-larger radiator
When I pulled the upper radiator hose to install a roe bleeder it had absolutely no coolant in that hose ( it was bone dry). Thoughts?
-water pump
-thermostat
-larger radiator
