how many qts. of oil are required to do a tranny fluid change.......
Jay Herbert
Sunnyvale, CA
I found the easiest way to do this was to run a rubber hose (approx 3 ft if I recall) down through the drivers side of the engine bay down into the tranny filler hole, stick a funnel into the end of the hose and pour in the fluid.
Just keep adding intil it is pouring all over the floor :) OK, better to put an oil drain pan below the tranny ;)
venomblue550
i remember chuck told me to check on the tag on the side of the tranny case to see what kinda of tranny fuild does the car takes, so will the Castrol Syntorque LT (Mopar #4874459) fit all type?? what kinda of fuild supposed to go in on a 96 GTS?? thanks
95Viper
Phoenix
Take Jay's advice...I didn't know about the difficulties of getting fluid into the tranny. Ended up going to h/w store and getting a 3 foot tube that just fit inside the filler hole. Easy then.
ViperJoe
Virginia
I think the real early Gen1 cars used something else.
Syntorqe is for the Gen2 which would be correct for the 96 GTS
Jack B
NE Ohio
A small hand pump is just as easy and you don't run the risk of fouling up the interior.
tractor1996
