I need help - buys viper history and datas
breeder_FCI
POLAND
Hi My name is Piotr!
I'm going to buy a Viper in 12 hours :) 1B3BR65E0PV200302
I would like to know its history, apparently it was exported at 11 miles.
You will help with the history and decoding the VIN.
it now has 8,000 ml - how much is it worth?
What typical faults should you pay attention to? :)
Thank you!
1993 RT? Does it have a rear antenna? Cool year, check to see if the head gaskets have been replaced. OEM was paper, newer are TLS.
At approx. build date 04/04/93 following changes occurred:
  1. Rear antenna replaced by windshield antenna wire
  2. Battery relocated to left rear fender (side away from fuel filler to make room for BUX rear exit exhaust)
  3. Front caliper lettering changed from "VIPER" to "RT/10"
  4. Reverse lockout added to transmission
  5. Top Material Changed from Vinyl to Cloth
