I need some help with my coolant system
HOdbleFman
Hurricane, WV
Ok, here is the deal on my 98 GTS. I noticed that the needle on the temperature gauge was fluctuating slightly at cruising speed, but the fluctuation was minimal. Probably no more than 5 degrees or so. Then it got worse and at slow speeds or idle the engine was heating up to the mark(.)
\ \ \|/ ./ / Before this the
190 250
temperature even at idle on hot days never got past the mark past 190 and it certainly didn't fluctuate very much during driving. Also, at highway speed in the past, the car ran a bit below the 190 tick, now it won't go below 195 or so. Well, I figured it was time to go see my friendly (haha) viper tech. He alerted me to the problem of a leaking gasket around the thermostat housing and told me that this was the problem. So, I had him replace this gasket as well as the thermostat and of course he had to flush the coolant system and put in new coolant. On the drive home I watched the gauge and the symptoms were still the same however at highway speed it did go back down to below the 190 tick again, but it still fluctuated and at slow speeds and idle it behaved as before and went back up to the high mark again. Now, I don't know what to do. I'm going to try and "burp" the system as in JobB's instructions tomorrow. I also read in some previous posts of someone who experienced similar symptoms, that the water pump should be looked at. I read that if you turn the heat on in the car and no hot air comes out that the water pump could be to blame. I tried this and I got heat from the defroster and from the floor vents, but not from the panel vents. I don't know what to do. Help please.
Ron
Indianapolis
GEN I and II Vipers do not supply heat to the panel vents. Floor and defrost only.
In addition, there is no temp mixing when you move the temp dial. Full heat or no heat is the only option.
H
HOdbleFman
Hurricane, WV
Oh it comes on at about 223 or so and it cools down until the fan kicks off or I start moving fast. If I continue to sit or go slowly it gets hot again and quickly until the fan kicks on again.
Birvini
Plainfield, Illinois
If the fan is working it is probably normal. We put 180 thermostats in both Vipers and it helps to delay the process of getting hot. These cars run hot, not much you can do about it.
You might want to do a search on this subject. There have been a lot of posts regarding this issue.
H
HOdbleFman
Hurricane, WV
How are the water pumps in the 98 GTS? Could this be the problem? I already burped the system today and it still does this.
ROIII
