Identifying Trouble Codes Without DRB on 2001
Tomcat
Woodstock, GA
I tried what the D-C Service Manual recommends: ignition on - off - on - off - on within 5 seconds. A search said that the check engine light will flash to provide the code (pauses between numbers). No luck at all. Check engine light is on and the procedure as noted above yields nothing in the way of a flashing check engine light. Should this procedure work on a 2001? Any help would be appreciated. I don't want to spend $150 plus on a DRB just yet.
thanks
Snake Bitten
Southern Kalifornia
This is not going to work on your 2001...doesn't on my 2000 either...you can run up to a Pep Boys, AutoZone, Checkers, etc...and have them read the codes for you, typically free...And when you get a chance, call up Summit Racing and order an EQUUS 3100...super easy to use and inexpensive through Summit...$127 I think plus shipping, and if it is not in stock, they can drop ship from manufacturer, even overnight...but close to $150 when all said and done...still a great bargain.
SUN RA KAT
Guest
I got my Equus 3100 from Summit Racing for $140.55 total within 2 days after ordering it.
TX WHOS YOUR DADDY
TOM,DO YOURSELF A FAVOR AND DROP 150 BUCKS.....IVE GOT AN ACTRON OBD 2 I BOUGHT AT AUTOZONE.COMES WITH CODE BOOK AND IF U NEED MORE INFO A TOLLFREE 800 NUMBER.U CAN READ AND CLEAR CODES FROM THE HAND HELD UNIT.ITS WORTH EVERY PENNY.GOOD LUCK! NORM KOERNER-CAR GUY
T
Tomcat
Woodstock, GA
Thanks Norm. Does that Scan Tool read all the codes? A TSB for 2001's #25-001--1 Feb 01 notes that some "generic Scan Tools will not display certain DTC's".
Tom
TX WHOS YOUR DADDY
TOM,AS FAR AS I KNOW IT WILL READ ALL CODES.HERES THIER TECH LINE SUPPORT NUMBER 1-800-228-7667 8AM TO 6PM MONDAY-FRIDAY.GIVE THEM A CALL AND VERIFY THAT THE ACTRON OBD2 MODEL CP9135 WILL HANDLE YOUR SNAKE.THIS SHOULD CLEAR UP ANY QUESTIONS.LIKE I SAID IT WORKS GREAT!NORM KOERNER-CAR GUY
Viper Wizard
South Salem, NY USA
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Tomcat:
You think D-C would update the Service Manual.
<HR></BLOCKQUOTE>
They do all the time [for the Dealers]. I'm not sure how the GP would get their updates.
T
Tomcat
Woodstock, GA
Ok, I will come clean. Unplugged the Skip Shift (I know, if I shifted like a man I would not need to unplug the Skip Shift)and you know what happened. If I buy a scan tool and clear the code, will the check engine light come back on?
Thanks, Tom
Viper Wizard
South Salem, NY USA
<HR></BLOCKQUOTE>
TSB #25-001-01 is for 2001 vehicles built prior to January 12,2001 [MDH 0112XX] that do not already have the PCM software at the 2001 calibration 14 revision level.
Vehicles: AB,AN,BR/BE,DN,SR,TJ&WJ
A generic scan tool may not display certain Diagnostic Trouble Codes [DTC] when a Malfunction Indicator Lamp [MIL] illuminates. This condition may occur on any 2001 Jeep, Truck, or Viper vehicle. This condition may not be a concern if an enhanced scan tool, like the DRBIII, is used to read the DTC. The DTC's that may not display on the generic scan tool are:
a. P0031 - O2 sensor 1/1 heater circuit low
b. P0032 - O2 sensor 1/1 heater circuit high
c. P0037 - O2 sensor 1/2 heater circuit low
d. P0038 - O2 sensor 1/2 heater circuit high
e. P0051 - O2 sensor 2/1 heater circuit low
f. P0052 - O2 sensor 2/1 heater circuit high
g. P0071 - Ambient temperature sensor performance
Viper Wizard
South Salem, NY USA
Thanks, Tom
<HR></BLOCKQUOTE>
YES!
You'll need to plug in a "Skip shift eliminator".
GEE I've never notice that feature in my Viper and it's pluged in.
Viper Wizard, please correct me if I'm wrong...but I thought that the MIL light would go out on it's own in 3-4 driving cycles AFTER the problem corrected (in this case, re-plugging in the skip shift eliminator. THANKS !!!
Viper Wizard
South Salem, NY USA
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Steve-Indy:
<HR></BLOCKQUOTE>
Yes it will, but it may take more then 3 or 4 driving cycles. It depends on driving time, loads, temps, speeds, ect. The Pcm must meet its criteria for a "good global trip" and it has to do it twice before turning the MIL light off.
TX WHOS YOUR DADDY
TOM,HERES ANOTHER CLEAR THE CHECK ENGINE LIGHT TIP.DISCONNET YOUR POSITIVE BATTERY TERMINAL FIRST THEN UNPLUG THE THREE PLUGS GOING INTO THE PCM ON THE SIDE OF THE PCM.WAIT 5 MINUTES.PLUG THE THREE PLUGS BACK INTO THE PCM AND RE CONNECT YOUR POSITIVE BATTERY TERMINAL.WHEN U START YOUR SNAKE UP THE CHECK ENGINE LIGHT WILL BE OFF.GOOD LUCK! NORM KOERNER-CAR GUY
Thanks, Wizard. I personally enjoy having the Scan Tool handy...almost a NECESSITY to have ( to clear ALL the codes set weekly) in my daily driver...2002 DeVille.
tractor1996
