Nsane1
Installed the kickers, great upgrade for under $50. Thanks for the help!!
So where did you get them for under $50?Installed the kickers, great upgrade for under $50. Thanks for the help!!
I installed the diamond speakers today and they are such an upgrade. Best of all they are components so I replaced both door and dash speakers. The doors speakers needed to be re-drilled to fit the speaker grills. The dash are easy pull covers off and install. It works great with the factory crossover settings. I can turn radio up to full volume with no distortion. They could handle more power than factory amp puts out. My new subwoffer will be here tomorrow so I will be installing it shortly, and let you know how that goes.
Joshua
Thanks to everyone in this thread. I can't speak for others, but I'm reading and taking notes.
I just installed a Kicker 6" subwoofer between the seats. Huge improvement. Had to bolt thru the enclosure to keep it from blowing apart. Sounds clearer, louder and deeper than stock. Best $72 I could spend. Check online. Found mine for $59 plus shipping.
ok ok ok, i've had enough... you cheap ******** buy $100k cars and put aftermarket speakers in them that cost $50!!! ***... either leave them alone and listen to the snake purr or do it right. I'm guessing that most people that have these cars are either very successful high end peeps that appreciate the finer things in life (this doesn't include the KS Kicker speaker series) and can tell the difference between a $25 speaker ($50 for two) and a $500 set.
do you yahoo's realize that the nav deck is $1600 from Chrysler? why would you upgrade using a pos speaker?
flame away...
the 2nd type of viper driver is a viper driver... that is they ordered the acr extreme or are usually driving so fast that they don't turn on the stereo or their top is down
p.s. if you want to do it "right" sort of, then do this...
all kicker speakers... 6.5, 4x6 behind the headrest and 2-10's...
Crutchfield has these Kicker ks600 speakers on sale for $49.99 with free shipping.I'll let you know how they sound.
Fair enough do tell Nader? What did I do wrong? Trunk space?!?
i think seabass is only jesting with us , besides this is doing it right
