BTW Chad DO NOT LET SOMEONE DYE YOUR OTHER INTERIOR PIECES. IT WILL PEEL OFF. OR CHANGE COLORS. I used to dye some door panel inserts and now they have come back to haunt me. Take if from someone who has been there and done that. I can give you references of work that others have had done that I have had to go back in and fix, just recently.
Chad you do great work, and are more than fair. I have seen your stuff up close and it is perfect. Half the cost of Venzano and equals the quality. But I disagree with dying the hard plastic pcs. If you prep them correctly they will last. I did mine over 2 years ago and no problems. In fact most OEM interior trim pcs come unfinished and you have to paint/dye to match. SEM makes a complete line of ready to spray colors. You have to clean the part good using a plastic prep and spray in med light coats. I would not recommend trying to dye carpet or seat covers, but the door panels, knee bolsters and center pc are all prime canidates for recoloring. I don't think Ed meant you were charging the infamous Viper Tax, just that you could have the seats recovered and done at your local uplustery shop. They would not have the same logos you do or the range of leathers, but still could look nice, much better than the OEM on an old Gen 1.
