Interior trunk release RT/10?
GTSHolgi
Germany - Rheinland
Hi,
I know, that the GTS was equipped with an interior hatch release as of MY99 (I believe). Is there any MY of the roadster which also came with a (stock) interior release handle?
Also, has anyone successfully installed a stock interior release handle into an RT/10 of an earlier MY RT/10 (which did not come with it by factory)? Is it possible to use the GTS parts in an RT/10?
Thanks,
Holger
VIPER BAZ UK
ENGLAND
No RT/10's came with the internal trunk release .. Snakoyl do one although a little expensive..
Would like this on my 02 RT as well...
G
GTSHolgi
Germany - Rheinland
I mean inside the cabin on the left side of the driver floor, like the GTS from MY99 on. I know about the electric version from Snakeoyl but I am preferring the stock solution of the GTS. I just don't know, if this could be applied to the RT/10 as the trunk lock is with the "moving/opening" part, different to the GTS where the lock is in the static rear body part??
Holger
Grisoman
do you mean inside the cabin or inside the trunk?
Cabin for sure. Since most times I leave my trunk gently resting on its bump stops (unlatched), I don't have to fumble around with a key to open it.
02ViperTodd
Lawrenceville, GA
My 02' RT came with an interior release. It's in the trunk, not the cabin. I thought it odd when I saw it considering anyone stuffed in the trunk would have to be broken in two to fit.
rharon
