Talon
I have a 99 GTS. I am having an intermittent issue with rolling down the drivers side window. Anyone have some thoughts? I don't believe the wiring is the problem since that already went bad, and I pulled the wires out and re-wired them...I believe I tugged on all the wires to force any unbroken brittle ones to break so that I could do them at the same time. I suppose it's possible one of them decided to fail now though.
When the window wasn't rolling down, if I opened the door and gave the slightest downward pressure on the window it rolled all the way down nice and smooth as if nothing was ever wrong in the first place. I'm not sure if this is indicative of something or not. This morning I tried the trick and nothing.
Any high level easy things I should be checking first? I haven't yet, but I will plan on popping off the dash and making sure I got a good connection at the window switch in the dash.
