Vital Velocity
It seems the air itself is fairly cool/cold but the system just doesnt move that much air. In my dd 05 vette(and just about every other car) it blows MUCH harder
Everybody knows how hard 'Vettes blow.
I hadn't thought about plugging the passenger crotch outlet. I have the control to turn the fan on, and have removed my cats already.
Maybe it's just me, but in my 97 GTS the a/c blows sufficiently cold to the point that I need to turn the temp up slightly, even when on the first setting.
You know when the dial is turned to the dash vents or AC running the temp dial doesn't control anything, right?Maybe it's just me, but in my 97 GTS the a/c blows sufficiently cold to the point that I need to turn the temp up slightly, even when on the first setting.
Not sure what you mean, when I have the A/C on (the snowflake or recirc) moving the dial changes the temp coming out.You know when the dial is turned to the dash vents or AC running the temp dial doesn't control anything, right?
Same here my gen1 blows ice cold like any newer car
