SylvanSRT
sidewinders are also a bargin
Unboxed my CCW SP16a's today. Little disappointed in the weights, about 23 pounds up front, 26 rear. That was with the center caps in, might be a bit lighter without 'em. On the plus side, the offsets were built how I wanted (1/4" less than stock), so I won't have to deal with spacers.
My data shows:
Stock 10 spoke wheels: 29 pounds front, 34 pounds rear
Stock Michelin runflats: 31 pounds front, 38 pounds rear
CCW SP16a wheels (stock 18x10 and 19x13 size): 23 pounds front, 26 pounds rear
Hoosier A6: 27 pounds front (315 or 335), 24 pounds front (285), 29 pounds rear (345)
That means I'll lose a total of (6 wheel + 4 tire), or 10 pounds/corner up front, and (8 wheel + 9 tire), or 17 pounds/corner out back. That's 54 pounds altogether, not too bad. If the 17lb. front weight for the Sidewinder is to be believed, those wheels with Hoosiers would be another 12 pounds lighter, for a total of 66.
The SRT-10 coupe I saw pics of from the Solo2 National Championship last year was running the 285's up front on Sidewinders, a theoretical 72lb. savings. Not sure the grip sacrifice from the smaller fronts is worth the weight savings though.
With the straight pipe cat-back exhaust, should be >100 pounds savings overall.
My data shows:
Rich, that isn't really a function of the rim design, just a function of how wide the OEM wants to go on a given width wheel. A 10" wide wheel can physically accomodate a tire quite a bit wider than 295. While at the outer limits of fitment wheel design can come in to play in for ease of mounting (as does sidewall stiffness and design variation between tires) we won't really be pushing those boundaries on the stock-sized front wheels, even with 315's. That's more for the guys putting 275's on 6.5" wheels and the like...
