So I finished up my head/cam swap tonight and fired the car up for the first time. Sounded weird the first time and then I remembered that I had forgotten to reconnect the O2 sensors on the driver's side (driver's side exhaust was the last thing I installed so I was getting anxious at that point). So I hooked up the sensors, cleared the codes, and fired her up again.
However, there was this thumping noise (it seemed really loud too me but I may be overreacting) that would happen every so often. It happened often at first (not constant, but it was consistent), but kind of went away. Mind you that I had installed one of Todd's tunes beforehand so maybe there was some relearning going on. As the car warmed up the noise pretty much went away. I didn't want to bring the RPMs up in the garage so I decided to pull it outside and rev it up a little bit. No thumping noise whatsoever under load (I brought it up all the way to 4K RPMs).
I came back inside to do a little research for about an hour and then went back outside and started it up again. I only heard the noise once over the course of 15 minutes. It almost sounded below the car, but I couldn't pinpoint it as it never happened when I was out of the car. I did install a ton of other things at the same time (slow bleed lifters, hardened push rods, plugs, plug wires, poly engine and trans mounts, MGW shifter) so I don't really know what it could be.
Does anyone know what this could be or what I should start checking first? Should I be worried since the noise has almost completely disappeared (I'm going to test it out again tomorrow morning)? FWIW, I went with NGK BKR6E plugs based on Todd's recommendation. I also noticed that the oil pressure dropped to 23-24 PSI at idle after the car warmed up but I think that's normal (it was 55-60 PSI at 3k RPM). Can anyone ease my anxiety about this and chalk it up to everything settling in after the install?
