mirror loose
tim bob
my drivers side mirror is getting loose do i need to take door panels apart to tighten 94 rt
Brake Dust
On my 96 GTS I folded the top back and the bolts are right there in the base.
T
tim bob
thanks i will try this weekend that sounds a lot easier than ripping my door panel apart.
RapidTransit
Concord,Ca
I was going to ask this also, but thought I should get a service manual first. Thanks, I,m off to tighten it up now!:D
RapidTransit
Concord,Ca
OK, those two bolts were a little loose. But the mirror is wobbling at the pivot,not the base...do I need to get a new mirror assembly? :confused:
Brake Dust
Remove those two bolts and remove the base, flip it over and tighten the nut it the center. If I recall correctly.
T
tim bob
the whole mirror assembly turns do i need to lift up on it or anything it feels pretty tight???
Tom F&L GoR
Wappingers Falls
More details, please, on what is turning and what is tight.
From the parts manual, which is in the illustrated guide section:
tractor1996
