Moton Suspension Spring Rates
Dimitrios
Queens, New York
purchasing a set of motons and was wodering which spring rates you guys are you using. will probably track the car twice a year. mostly for street use. thanks
Hiss
Kentucky
I am using 800 rear 500 front. Use mostly for street. These rates are working real well.
ILLSMOQ
SAN JOSE, CA
I've got 500 and 700. I drive like an a$$hole, so I should have gone with a little more in the rear
Nader
New York
Dimitrios I am looking into the moton set up as well and most recommend 500 front 800 rear. Are you having chuck do the install? Curious to see what your plans are since I am in Brooklyn and deal with similar roads. What settings are you planning? How low do you plan on going?
Scott_in_FL
Boca Raton, FL
500 front and 800 rear here as well. Seems to work great for spirited street driving. Might use a bit more on the track.
Viper X
500 front, 800 rear with helpers and 200 lbs of nitrogen gas pressure in the cannisters.
Car is very stable on the track. Lighten the rebound and compression settings and it can be very comfortable on the street, even on rough roads.
tractor1996
