musicncars - u were asking about stereo upgrades while back
wallbanger
from the alley
Al & Eds Autosound of Santa Monica
musicncars
The Mountains
wow....thats an audio solution that i could use. can anyone point me in the right direction to someone who does this and this well?? Thanks, wallbanger, that is very sharp.:2tu:
VIPER GTSR 91
Spring, Texas
YES, "Unigue Whips" Elite Motorsports in upstate New York. (speed channel) ask for Booju. Google for phone.
musicncars
The Mountains
Rather than start a new thread, I will just ask on here. How do you remove the door panels? Does anyone have any pics showing this process? Ive got some speakers, now I need to install them.
Thanks,
WANTED
Thanks,
If your only changing the stock speakers with replacements, NO NEED TO
REMOVE DOOR PANELS. You can PM me I should be able to help you. The
entire process will take about 30 minutes max.
Darbgnik
Fort McMurray, Alberta, Canada
Did you change your speakers music? If you need anymore info I changed all of mine will give you any info you would like.
I'm just about to order 6" JL VR600-CSi Components (well my girlfriend is for my 30th birthday:D), and seeing as you've done it I might as well double check.
The factory in-dash tweeter is 3/4"?
To get at them you just pull the grill in the dash off with a pick?
You mentioned factory crossovers in another post, they're integral to the factory amplifier correct?
You said the diamond tweeter was a direct drop in, but I can't find the size of the Diamond tweeter(hoping 3/4")
Thanks Brad
viperfuntime
San Diego
Where do the crossovers go if you upgrade to the Diamond D362 6 inch components?
Tweeter in dash and mid in door but what about the crossover?
VicTxV10
Victoria, TX
I was told if use the factory amp and wires, the crossover is built in already to protect the factory tweeters in dash.
08viperviolet
coral gables FL
did not use crossover factory amp has a crossover function due to the fact they set it up as a component setup. You could mount them next to the amp under passenger seat. PM if you need more info.
