Greg Good Cylinder Heads
The reason you don't see faster times from some of these cars is that the power does not get put to the ground. Without clutch management and a little chassis/shock work the car will not run to its full potential.
Doesn't mean the dyno number is bogus, it just means the owner needs a crewchief.
I have found chassis dyno's to be good indicators of power, meaning that if one does well on a chassis dyno, it will normally run fast down the track, assuming the driving, clutch, and chassis are in order. A water brake engine dyno is a different story. I have seen many things pick up an engine on a Superflow type dyno but run slower at the track.
