Be good to have any Big "All Motor Die Hards" chime in here.
Ive decided to take my 2005 Copperhead to new performance heights.
Of the dozen so sports cars ive owned over the years this is gonna be a first for me....The All motor build for high HP and reliability!
My Paxton has been set aside and just like to see what we can do with only a Motor.
Prior to installing the Paxton (which did 733rwhp - dyno dynamics dyno), I did 530 (on same dyno) with simple bolt on headers, no cats, stock mufflers, intake, TB, and VEC3 custom tune.
At this time the motor is out and the heads are off so ive past the point of no return!!!!
Todd Abrams, owner A&C Performance in Murrietta, CA is in charge of the build, installation and tune.
Greg Good, In Houston, is on the heads, cam and intake
We are in the early stages and I sure like this to be a 700rwhp all motor bullet proof project... we will see if costs, 91 octane and drivebility limitations are gonna slow me down on this one. It likely be costs more so than the crappy gas!
Thus far i have heard staying at 10:5 compression is very wise to be safe.
I'm not too interested in a crazy idle, so im not to sure if the 700 is gonna happen.
So far we have discussed 521 stroker or the bigger 542.
Id sure like to have a 6500 redline.
Were definetely gonna improve the oiling system.
It be great to hear any opinions and experiences of those who have been through an all motor project
I will also be glad to update everyone on this projects and inform where its goes.
So... much more to come!!!
Hi,
Lots of talk about dynos here. In the end they are a tuning tool. Dynojets are typically 10% higher (around here), than Mustangs or a Dyno Dynamics dyno, like we use. So regardless of what a given dyno spits out, I use the numbers to check if a mod helped or hurt.
And as mentioned, dyno numbers can be
easily manipulated, just like the numbers coming from a flow bench for cylinder heads.
And yes, the M.P.H. numbers at the track can quickly separate fact from fiction. It takes a certain amount of power to accelerate a given weight to a certain m.p.h. That's about it.
So regardless of the horsepower someone has, or think they have, tracks are a great place to cut to the chase, so to speak.
As for your request for results of N.A. Gen III mods: My current project was a simple one. Take a stock Gen III in an SRT-10 truck and bolt on a cat-back system, a set of Strikers (10.5:1) and a mild roller and see what happens. NO headers, cold air intake or intake manifold mods. And a mail-order tune, installed through an SCT controller. Also, the engine has never been out of the truck. I began with the cat-back system, ported throttle body and a tune and the net result was 433 wheel. On went the Strikers and in went a small roller cam.
End result through an automatic transmission: 577 wheel and 607 torque.
"Add" 30 more horsepower through a manual transmission. So, "corrected", a tick over 600 wheel (in a Viper car for example). Completely streetable and reliable, with all of the stock reciprocating parts (60,000 miles later). Improved gas mileage too !! VERY wide power band and a 6050 shift point. LOTS of torque, which is what a 5600 pound vehicle needs.
Side note: Heads are where the power
is actually made, so especially in a N.A. application, I would concentrate $$$ and research there.
I've heard some wild claims about flow numbers through the o.e.m. castings. There is only .200" wall to work with and the Gen IIIs are already (basically) a factory-ported Gen II casting and are pretty decent. Can improvements be made? Yes, certainly, but only to a point. Will a major porting job on Gen IIIs
outperform a set of Strikers? No, it won't.
I seriously doubt claims of 320+ c.f.m. at 28" on a set of ported Gen IIIs. I would really like to see the 320+ for one thing on a bench, and then test them to see how much power those heads actually make
ALL BY THEMSELVES.
Can porting Strikers increase the flow numbers? Yes, it can.
Will porting a set of Strikers produce more power than an off the shelf set? Maybe, but it's not an absolute. There again, some wild flow claims have been made. An actual A-B test is the true way to see if the porting worked well or not.
And, unfortunately big flow numbers, almost exclusively, help to sell heads. But there is more to it than that.
TRUE flow numbers are one thing to consider when either purchasing or modifying your Stockers/Strikers but
QUALITY of flow is quite another. That one isn't talked about very much at all... I've seen some big number claims on both the ported o.e.m.s and ported Strikers that were, in reality, terrible. The heads looked great, nice finishing work and a massive amount of port hogging, (in some cases) but the engine itself didn't really like them much.
By pulling the heads and
looking at the piston top and combustion chamber burn-patterns, it can tell a lot about what is going on in there. Even an improperly shaped intake port (flattened short-turn, for example) can produce higher flow numbers than stock. But, because liquid fuel doesn't burn, and because of the improper port shape, fuel and air have separated, (in this example)the heads end up having very poor combustion efficiency on an actual working engine. So sometimes the big flow numbers can produce FAR LESS power than you would expect. And in some cases, even a power
loss over a set of stock heads.
Please don't misunderstand me as there are some very good head porters out there, but the flow claims can sometimes get out of hand. So try to determine HOW MUCH POWER THE PORTED HEADS ACTUALLY MAKE over a non-ported version, rather than listening strictly to flow claims. After all, it is the increase
in power you are trying to obtain.
This is a bit of a lengthy post to reinforce the issue that it is the heads in the end, (the combustion chamber) that actually
produce the power. So porting decisions or head purchasing choices are important if planning to obtain a large power increase in a n.a. application.
So 600 wheel for me, in my example was relatively easy.
Can another 100 horsepower be obtained to hit your 700 wheel goal? Sure. Will some drivability sacrifices be made? Probably. 600 is one thing, 700 wheel is quite another. That extra 100 horsepower will likely come through a rather big jump in compression and a radical cam profile. Those 2 items will change the engine rules between what is considered pump gas street and what will be a strip machine.
It is far easier to pick up say, 150 wheel on a Gen III engine than a Gen IV that already have the good heads and THAT is where the lion's share of that extra 100 horsepower came from.
My 2 cents ...
Hope this helps©
Ronnie
