Need dome light switch for 98 GTS - Dodge does not have part #
PhoenixGTS
Phoenix Arizona
I had one of the switches you can push to turn a dome light on when the doors are closed fail and apparently it is not a part that is available from Dodge. Any ideas for a used one or if it comes from another application (has to as it has threads on it that are not used in the Viper installation)?
luc
Paso Robles CA
The swichtes and lamps come with the headliner.
Open the switch and see what the problem is, maybe the contacts are just dirty/corroded.
Luc.00GTS
PhoenixGTS
PhoenixGTS
Phoenix Arizona
Luc.00GTS
Yep only comes with the $1,100 headliner. Switch is sealed unit that I do not think I could get apart. I am going to look harder for used but fall-back position is to convert both to toggles. Ugh!
tractor1996
