I am putting on 20" forgelines all around with stock widths.
I am looking at Pirelli Rosso or Nitto Invo's.
I understand the Nittos cost less and have a softer sidewall, but it appears the Nitto 285/25/20's will give me almost the exact same diameter as the stock runflats. I have tracked my car once and am not sure if/when I will do so again.
The Rosso's closest size is 285/30/20.
The tire size calculator at Discount tells me the Pirelli is 1.15 inches taller.
So, which is the lesser of two evils? Softer sidewalls on the Invo's or larger diameter with possible rubbing issues on the Pirelli's? My car is lowered 1.125". I am pretty sure I want to stick with 20's in the front either way.
If you have either tire or expertise on the subject, I welcome your comments on this.
