V
vegasviper
Guest
Any help would be great. Engine breaks up at 5000 to 6000RPM and seems to run better with check engine light(MAP low input)on. I replaced the MAP, TPS, grounded bat. sensor and TPS and no change. I swaped PCM from 99ACR to my 97 GTS and it seemed worse at the same RPM. I did notice shutting car off and starting again sometimes cures problem. Sometimes it takes 3 or 4 times starting and shutting engine off to cure RPM problem. The RPM break up only happens under WOT only, if i let off just a hair it RPM just fine.
