In the world of internal combustion engines, there ain't no such thing as a free lunch. This stuff will make your engine run hotter than stock according to someone who has tried it. Caveat emptor.
Well,
I guess I am the first to try it. It has been in my car for about 8 months, and I have had no problems with it. My car does have a Griffin racing radiator and a 180 thermostate though....
I've run it in my car and it didn't make any difference in the operating temperature of the engine. The concept is that it will allow your engine to run at a higher temperature without negative effects. It did NOT lower the temperatures if that's what you're after.
I used it on a Ford 27 5 window with a blown 355 chevy, the coolant solved the problem of running 210 degrees with regular coolant to 195 with evans NPG+
