I am guessing that you are asking this question due to reading a code? Anyway, your #2 O2 sensor is not in the normal location, given the mods to your car. Perhaps it is not installed at all if the previous owner did a cat delete. It would normally be in the exhaust pipe after it exits the side sill and turns the corner in front of the rear wheel, in the pipe going to the rear exit. They might have relocated the sensor to the pipe inside the side sill. By the way, the only Viper service manual that I know of on the web is for a '98, thanks to a fellow Viper owner on the forums. https://docs.google.com/file/d/0Bwwp-Q86mAaic3J5MWNKS2pLdk0/edit
