Re: Response to the Hostility
BOB, I don't know if you deserve my help or any help. Because you are digging into more and more troubles and I think nobody wants to help you. But here we go and this is the last time I try to help you.
Did you read post #3 answer #2 ?
Because we had exactly the same trouble with a Viper at 5000rpm as you described in question #5. And the fix was to change the PCM. Some people also advised to put additional grounds on the sensors which helped but didn't elliminate the troubles with the ignition. Yes this Viper was running 100%perfectly without supercharger. But some parts in this stupid PCM were made in a 3rd world country to save a couple of $$$ to Chrysler and the PCM didn't like the additional charge on the electrical system.
Now I even managed to find the dyno sheet on this trouble. 100% same sympthomes than yours: Viper running way too rich and no more ignition from 5000rpm. Sorry but I don't listen to AM radio so I have no idea if AM frequency had statics but next time I have a similar issue I will listen to it. Once PCM was change this Viper turned into a rocket.
Now if you think that I just made this dyno sheet on photoshop check this video. And espectially watch the last few seconds when Viper revs 5000rpm in 4th gear. You will see the smoke coming out the exhaust and the hesitation of the engin. Yes this is a PCM issue and not a VEC2 issue.
And all this help is FREE for the Viper community ...
Sean, the question raised in paragraph five is not answered in any of your replies.
