cdover73
My 03 vert driver's door isnt lowering enough to clear the seal when closing with the top up. I had the regulator replaced and they said the track was good. Im sure it is a programming issue but the hold down then hold up and repeat x 3 sequence doesnt work. With the door open I can roll it all the way up and it only drops about 1/8". The passenger side works fine and lowers about 1/4". Does anyone know the trick to this? Again, new regulator, track is good including the teflon piece, seals arent torn, and nothing is in a bind. Should I try unhooking the battery? Anything else?
Oh, we did have it working one time but they(dealership) did something else instead of leaving it alone and now we cant get it back right.
Thanks,
Thanks,
