Tech Question......OK I'm also thinking of going down this route, but I have a question? If removing the stock flywheel these are normally balanced? If you replace the Flywheel with a lightweight one is there a correct position where it fits on the car? Or are the bolt holes fixed for one position only? Having never seen the end of the crankshaft is this something to be concerned about? Its that reading about low speed bucking, I'm wondering if flywheel positioning may be a factor?
Mark
The low speed 'bucking' is a (mostly) 96-99 Viper issue. The large overlap of teh camshaft means that the engine runs the roughest and that causes the shake at idle. Lightening the flywheel and reciprocating engine parts increases this 'bucking/shaking of the engine. If you added 30# more to the flywheel the reciprocating weight would smooth the roughness if the idle but really slow down engine throttle response and hurt hp.
Because the "forged piston engine" runs rough many people (and magazines) were concerned that this isn't comfortable???? Personally, I could car less if my Viper idles rough. It sounds like there is over 800bhp under the hood and I don't think it should run smooth. My car is no sewing machine, it's a supercar. I ported my heads and match ported my intake manifold. Along with the increased hp this also increases the roughness of the idle. The CNC'd 2" long runners of my Roe sc intake manifold also causes the idle to be rougher than the smooth 08 idle. I like it like that. My engine responds instantly to any thottle movement. I don't notice the bucking, because like most surviving Viper owner/drivers I am a superior driver. I don't drive my car near the idle where it may buck.
Kinda like the Viper itself, a little rougher idle and a little more power. The lighter weight also makes my Viper handle better. You can call JonB, but I'd guess there's a 8# weight saving for Chrome-moly and 14-18# for aluminium flywheel. I spent thousands on upgrading to lighweight wheels and rotors to lighten my car so it'll handle a little better. I'm thoinking that my car weighs close to a vette so ... on the track they're in my way around corners and on the straights. Just as things are supposed to be.
Ted
