Radiators - The latest and greatest?
jay01m
Virginia
Gents - Did lots of research on this one when my radiator began crapping out. I only gleaned over what's been posted, so sorry if I repeat...
Good luck getting a hold of a Fluidyne Radiator. You'll see them for sale online, but after trying to make a purchase from 3 different vendors, all came back saying they are out of stock. Called Fluidyne, and they said they are no longer making them due to demand. This was about 10 months ago.
Aluminum radiators IMHO aren't worth it for a couple reasons: heard too many times where they start leaking early, the stock ones are completely rebuildable for hundreds less (and will probably last as long or longer), and most of all, I've heard from too many Viper builders who say there is no extra cooling gained from going with an aluminum radiator.
Triple Pass vs Single Pass - I recommend going single pass, which is the only way you can rebuild a stock radiator anyways, the tanks are not designed to go triple pass without some significant modding. Single pass radiators will also last longer because they are not as prone to obstructing flow due to corrosion as they age. Single passes use the entire height of the radiator to flow from one side to the other, whereas the triple pass uses 1/3 of that height (coolant goes across, down, back across, down, and across one more time, hence triple pass). As the radiator ages and begins to build up corrosion on the inside, the triple pass radiator will clog up much sooner than the single pass.
The stock radiators, as mentioned, come as a dual core (2 inches thick), but the tanks are built to accomodate a triple core (3 inches thick). I'm assuming Dodge was trying to save money when they did this, albeit stupid. Going triple core is a no brainer. It costs hardly any more than a dual core, and you're going to maximize the cooling ability of the radiator.
Bottom line, any good radiator shop in your local area can rebuild these radiators with a triple core no problem. For me, there's a shop here in Yorktown Virginia called Steve's Radiator, Steve's Radiator Service, who overhauled mine. Steve is a super nice guy, and did the complete build for under $600, and guaranteed the work. He even called me a month after I got it back and in the car to check on me and make sure I was happy. I am extremely happy, and I'd recommend him to anyone. While I'd love for you to use him if you need a rebuild, I'd check your local area first to compare prices. You might find a better deal where you live.
The results: Dave is right, besides heat exchange, the name of the game is air flow through the radiator. While the triple core doesn't prevent my GTS from getting hot (getting to the tick mark to the right of center, maybe 220?), it definitely takes quite a bit longer to get there. I think one big reason is lack of air flow through the radiator. I currently have no other mods for cooling, but I'm confident with an auxiliary fan project I'm working on, I should be able to get her to stay right at whatever my T-stat temp is.
The triple core looks exactly like the stocker, except thinner, but if you really want pics I can post a couple.
Just my $.02.
C
Chuck 98 RT/10
tampa, fl USA
I've decided to remain stock. I've never had a radiator related overheating problem with either my street Viper or my tracker. Why fix what aint broke? Except for the leak I mean.
Tom F&L GoR
Wappingers Falls
Is this right? I thought triple pass used the entire height (or width) but in the three cores, would go up one, down the next, then up the last one and exit. It means the flow rate has to be very high (vs. a single pass, where all three cores go the same direction at 1/3 the flow rate) and as you pointed out, the triple pass would be extremely negatively impacted by an obstruction. What would make the coolant "turn around" at 1/3 the height?
dave6666
Judging by the looks of the end tanks on my Roe triple pass, it's a zig-zag flow through all of the top third, then back the other way in the middle third, and then a U'ey back again to the pump suction.
I agree with what jay01m said that the aluminum units do not out perform the stocker, at least not the ones I've tried. I've also, like Chuck, never had an overheating issue here in Texas, but it runs on the edge of being adequate. I want a cushion in that capacity. Unlike the F1 drivers when they are at idle for an additional 10 seconds during a bad pit stop and risk overheating, I don't mind having a few extra pounds of cooling equipment for that cushion.
jay01m
Virginia
No, the cores' direction of flow is lateral, same as how Dave describes it, but the result of an obstruction is still the same, it would be a very negative impact.
jay01m
Virginia
Sorry, I meant to say the triple core is the same, except THICKER than the stocker. Each core is 1 inch thick on these, so the stock dual cores are 2 inches thick, and the triple cores are 3 inches thick.
LPDesRoche
Sunbury, NC
The only thing I have to add to this is I installed one of the new ROE aluminum radiatiors and it is performing great thus far. It cools better than my stocker (but I suspect it was due for a clean out)and fit like it was supposed to.
dave6666
I think your case is where putting an aluminum radiator in is justified; if your stock one is not performing well due to an issue. In my case, with a stock radiator that was in perfect shape, compared to aluminum radiators... negligible difference.
tractor1996
