Johann
In regard to the fuel pressure check valve the '97 service manual is somewhat vague. In the pump description it says the valve "maintains pump pressure during engine off conditions" and under the regulator description it says the valve "maintains some fuel pressure when the engine is not operating".
On my '97 when the key is turned to run the pressure rises quickly to 55 psi (book spec) but when the pump shuts off after one second the pressure drops in a few seconds to around 4-5 psi and holds there. If the check valve is supposed to hold "pump pressure" of 55 psi I've got a problem but if it only needs to hold "some" pressure I'm OK. Which is it?
