Hi,
I´ve been trying to solve the problem with my reverse lockout solenoid, but I cannot find any explanation for the behaviour it has. So here it is how it works on my 94 RT/10:
- key off: I can select reverse gear feeling some spring tension
- key on: Same as above
- cruising over 5MPH: reverse can be selected without any spring tension, so I can misshift from 4th to R when trying to go for 5th.
I have understood that when cruising over 5MPH it is impossible (or nearly impossible, requiring a lot of force) to select reverse gear. But now I can do it very easily, so I suspect something is not working correctly..?
I took the solenoid assembly out of the car and I also cannot understand how it is able to lock the reverse just by examing this part in my hands? Because without power/ground connection the sping/piston assembly is sticking out of the housing slightly and when I cruise over 5MPH the small pin inside retracts and the spring/piston assy is able to slide inside the housing almost completely...and I suspect this causes the shifter to be able to be used to select reverse without any spring tension, just like from 1-2 row to 3-4, for example.
And the reverse lock has been working on my car previously, but some time ago it didn´t prevent the reverse gear selection at over 5MPH anymore.
Can anyone expain how this system is mechanicly able to lockout reverse gear selection and how the solenoid should work? (when the pin inside should retard, etc...)
Thank you for your replies and thoughts about this & best greetings from Finland.
